Why attach projection not work in Luxology. I have a problem with textures on the elements where it is.
Projections should be working with Luxology, do you have a test case where they do not work?
Jerry
Sometimes it works. I do not know where to find the source of the problem. Most of wooden items to attach projection and are well rendered. However, the top of the chimney is not. The same problem I have with the other floors of this project.
A file with the roof
Do not know if this will help.
Moisés.
Can you post the version with your materials and projections this file does not have materials?
