After attaching a material to a face of a Triforma wall/slab + attaching a Projection, I would like to edit the orientation of the projection. I can use the rotate-cirkels, but after I've rotated, the map jumps back to it's original setting, same behaviour exist with the move and scale functions... When trying this out on a simple Solid, it works as it should.
Does anyone else noticed this behaviour?
Hi Michael,
Are you using Triforma when making the adjustments or MicroStation? It could be that the element or geometry is locked by the Triforma application. If this is true you should see a message in the message center indicating that the element is locked and you would need Triforma loaded to make this edit.
Cheers,
Jerry
I'm inside an AECOsim Building Designer environment, if that's what you mean? I'm not getting any error-messages in the status bar...
There is a known issue with projections not working with face attachments and triforma solids. I am waiting for the Triforma team to get back to me with more details.
Paul Chater
