Hi
I did this little model, but have some problems when trying to render it.
It will only render in "draft" and in no higher resolution then 1000*1000 pixels.
If I set up the resolution or change to a better render setting, it will only render the nose and the antenna.
Tried to change all kinds of settings, but I cannot get it to work...could really need some hints :-)
Hi Thomas,
There is something wrong with the smartsolids you're using. Simply convert them to mesh (Mesh from element). and it will render.
Regards Louis
Answer Verified By: Thomas Blom
Seems to work...thanks a lot :-)
Still wonder why it cant render the solids
