Hi
I did this little model, but have some problems when trying to render it.
It will only render in "draft" and in no higher resolution then 1000*1000 pixels.
If I set up the resolution or change to a better render setting, it will only render the nose and the antenna.
Tried to change all kinds of settings, but I cannot get it to work...could really need some hints :-)
Yes of course...had not thought of that.
Was planning to try to render it at another computer at work, but havent had the time yet.
The file should be attached here, so if you have the time to take a little look at it, I would appreciate it :-)
Hi, is modeled with MicroStation?
Moisés.
Hi Thomas,
There is something wrong with the smartsolids you're using. Simply convert them to mesh (Mesh from element). and it will render.
Regards Louis
Answer Verified By: Thomas Blom
Seems to work...thanks a lot :-)
Still wonder why it cant render the solids
