Assign material to entire level with RGB colored elements
Gentlemen,
How can I assign a material to an entire level regardless of the elements (RGB) color?
Imagine if you like that we have a gazillion different objects, with as many different RGB-colors, that can change at any given moment without our knowledge.
Is it possible?
  • open level manager
    turn on the material column
    add a material- if you click  on none at your level row it will bring up the material palette
    this will give you a material for everything on that level regardless of wireframe colour (but only as long as you dont have other material assignments as these will override the level option)
    is this what you are after?
    Answer Verified By: Torben
Reply
