visualization in Micro Station
How to change the color of the section view. It is all appearing in either white or as per color overrides for the visual edges. The 3D models does not have associated material. we would like to retain the colors of the elements as assigned to it by the level properties. I tried to set different presentation styles but in vain. The presentation style associated is by the clip volume. Also we are not able to apply the section lines ( patterns) for the cross section which is cut. Any suggestions?
