I'm having some trouble with the units of an imported DWG model.
As you can see on the screen capture, the smooth display represents the right scale.
When I render in Luxology the scale is different.
I have tried several adjustments in the 'Working Units Settings', but I can't get it right.
I only have this trouble when I import a CAD file of another source.
What am I overlooking?
Wim
Can you send me the data set to have a look?
Jerry
Just a thought:
The screen capture is showing the settings for the Sub Surface Color map. This tells me that you have unlinked them from the diffuse settings for the Pattern map. The Sub Surface Color map settings are linked to the diffuse settings by default. If you unlink them then the dimensions are no longer forced to be the same. You may have different dimensions for the Pattern map vs the Sub Surface Color map.
Hello Jerry,
Attached you can find the packager file.
Thanks!
Hello Ron,
The pattern map has the same dimension as the Sub Surface Color.
Thanks anyway,
wim
Have you had a chance to take a look at the data set?
