Trying to re-record a portion of a script, but when I do one of the materials disappears when the image is generated. I've re-synced the material to the library but no difference. It recorded everything fine last week so I don't know what happened. The material also disappears from the objects after I cancel the script recording and click on an object in a view. Any Ideas?? Again thanks for the help
What version of microstation do you have, what render mode are you using and what size image are you producing ?
Paul
What is your highlight color set to be? My guess is that you have that element selected and and you are seeing the highlight color. Clear you element selection and see if it appears correct.
Jerry
It appears that our CAD administrator was making some system changes that was interrupting the path connection to the materials. All is ok now.
Kevin
@Jerry: Is having a selection really causing errors when rendering animations?
System: Win7 64bit 16GB Ram - microStation V8i SS3 08.11.09.578. + PoinTools CONNECT. - Intel i7-4800MQ CPU@2.70GHz, 4 core / 8 Logic proc.
Hi Torbin,
I just check and it is not if rendering frames using record but if element is selected the animator preview will show it selected.
Cheers,
