Lens flares
Hello All,
Does Microstation have the ability to animate lens flares?
J
  • Hi J,
    No, MicroStation does not have the ability to animate lens flares. It also doesn't have the ability to add them. This can be done very easily in post with Photoshop.
    Regards Louis
  • Thanks Louis, I thought I remembered something about Jerry doing something with Effects Manager (maybe).
  • Photoshop is best bet for flare you can add bloom in MicroStation but not a lens flare. If you want to animate you do this in Adobe Premiere here is a sunrise movie I did a while back the flare was done in Premiere.
    Jerry
  • Jerry, that was sick!  I just tried to do a solar animation and it failed miserably.  I'm sure I have some settings I have to change.  I just wanted to show the shadows moving over time.  It never rendered.
