You will need to sign in with your single sign on user and password which is the same one you use to post here to see this.
http://learn.bentley.com/app/Public/GetLiveCourseOfferings?CourseId=105228&lpId=100083&FreeForAll=False
Cheers,
Jerry
Attend this class if you want to learn how to use MicroStation's Animator ;-)
Thats Great Jerry! I could sure use some brushing up on this.
I would probably join if I knew how to find it?
System: Win7 64bit 16GB Ram - microStation V8i SS3 08.11.09.578. + PoinTools CONNECT. - Intel i7-4800MQ CPU@2.70GHz, 4 core / 8 Logic proc.
Jerry, is this class full? I cannot seem to find it via the posted link.
Let me see what I can do, it is not full but they may have closed it down since it starts tomorrow. I will try to get it opened back up for you guys. You will need to be signed in for the link to work though.
This should be back up log in with your normal sign on credentials first and it should take you there.
