I get empty files
zero size, nada, nothing.
{SrvReqNo:[7000125294]}
regards / Thomas Voghera
I do get fbx-files if I try export from a file with one solid and and a ABD-wall. Also with only one ABD-wall.
But - but my full model gives zero-size fbx.
So something is disturbing the export. WHAT?
I encountered into the same problem with OBD update 7 - nothing were exported to FBX, zero bytes files only. With some testing I found out that the problem was that the project folder name had some special characters in it, like Estonian letter "ä" that is not part of English alphabet. Probably, Thomas, you had the same issue. I suggest that there can be fix in FBX exporter - please, Bentley programmers, take a look into it.
