Hi all,
A quick update: http://support.nextlimit.com/display/mxdocsv3/MicroStation
Enjoy,
From the documentation:
Supported platforms:
MicroStation V8i SELECTseries 3 Update 1 (or 2) v 08.11.09.357 (459)
Maxwell Studio / Maxwell Render v 3.0.1.0
These are the only versions the plug-in was certified on.
However, but only on your own risk, you may disable the built-in safety net and allow other sub-minor updates to be accepted by the plug-in (in your case, allow the *.747).
Simply define environment variable MS_MAXWELL_IGNORE_SUBMINOR_VERSION = 1 and off you go ;)
The outcome depends on sheer luck.
Cheers,
/Chris Z.
Hi All
Just looking at this post. I believe the plugin is no longer available as it is not listed in the link above. Also , if it was.. would it work in CE?
Ian
Hi Ian,
The most recent version of the plugin (v1.3.4) is compatible with MicroStation SS3 and Maxwell 3.2.1.5. Once Maxwell 4 was released, Nextlimit decided to discontinue support for quite a few host applications. It's a pity but Maxwell 3.2 is still a beautiful render engine and MicroStation SS3 is still a joy to use :-)
