I have a file with a background image (.sid) file It plots Well but when rendered the image does not render.
The background image is composed of tiled .sid files and then one large white rectangle placed over the top with a transparency of 80.
Looks good on screen. (I can;t figure out how else to make the image fade behind the graphics)
Can you email me a simplified version of your file so I can take a look.
Paul
Too big and I have to check if allowed
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Have you tried applying the image as a material draped on a surface?
There is not material to drape upon. this is down and dirty for drafting at low tolerance on a master plan. I may just ignore this step
Hi Eric,
Maybe try converting the SiD file http://www.lizardtech.com/support/knowledge-base-article/decoding-a-mrsid-file-to-other-formats/
Jerry
