When I take a model that renders and illustrates fine
Cut a Section
It looses all materials and give me a great white and black line image.
No changes to the display mode corrects this. I have tried with any model and once a section is cut I lose the materials and all color????
Eric,
Are you using a clip volume or a "dynamic" section tool? You have to shut off the level in level display / manager that may be why you are "whiting out".
...relative to your clip volume that is.
Actually are you using sheet models? Can you upload a file so I can take a look?
Not using sheet models and the file is now to big to upload
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
