I have a still rendering with some trees and plants that are placed in the scene with the RPC Placement tools. They look fine in the shaded view but when I run the Luxology Render the plants that I have placed in a circle around the tree fall behind the trunk. The tree's I am using are 3d RPC's and the plants are 2d RPC's. I have tried with the Raytrace and Exterior Best set ups with the same results. Any thoughts on what could be causing this?
If Nasir's suggestion of deleting cells and re-placing them doesn't work, please provide your compressed data set (including saved view of rendered scene) for testing and the version of MicroStation you are using.
The data set can be attached to a post in this thread. Access to these files can be restricted to Bentley colleagues by uploading with one of the following methods:
If the upload is successful, reply to this post indicating which method you used and the name of the compressed file you uploaded.
Craig Calvin
Bentley Technical Support
