Hello All,
I am designing a conveyor layout with trestles and transfer towers but unable to get MTO's of conveyor, trestles and junction towers.
Is there any way to calculate approximate MTO's.
I am also using Bently Pro steel to open the same model to design other steel infrastructure but unable to get MTO's of the already designed these structure from there too. Please help me ASAP.
Hi Kantidhar Dwivedi
MineCycle Material Handling is a product that facilitates the conceptual layout/design of materials handling equipment such as conveyors, hoppers, platforms, stockpiles, etc. As this is a conceptual design application, the design is then exported to other applications for detailed design and material take-off. An example is; conveyors that are exported to applications such as Sidewinder via a consensus model, for detailed design. The updated detailed design can then be re-imported back to MineCycle Material Handling and the model will be updated. May I suggest that you post this question on the ProSteel forum as well for more information from the team there?
Sonya Pieterse
Sonya
