Is it posssible to change a report template?
If yes, where can I find this template and how can I change it?
Hi Marek
Yes, you can edit the Reports using SAP Crystal Reports. You will need a license for this from SAP.
The reports and schema files are in the following folder if you have done a default installation:
C:\ProgramData\Bentley\Mining\Reports\8.11.9\en\
Sonya
Answer Verified By: Marek Sołowczuk
Thank You Sonya!
What about my service request 7000680197(apps.bentley.com/.../0)
regards,
Mraek
W dniu 28/09/17 02:02 SonyaP napisał:
> #outlook a {padding:0;}body{width:100% !important; -webkit-text-size-adjust:100%; -ms-text-size-adjust:100%; margin:0; padding:0; background: #ffffff;}.ExternalClass {width:100%;}.ExternalClass, .ExternalClass p, .ExternalClass span, .ExternalClass font, .ExternalClass td, .ExternalClass div {line-height: 100%;}#backgroundTable {margin:0; padding:0; width:100% !important; line-height: 100% !important;}img {outline:none; text-decoration:none; -ms-interpolation-mode: bicubic; max-width: 300px;} object, embed, video, table {max-width: 100%;}pre {max-width: auto; overflow:auto;}p {margin: 1em 0;}a {border:none;color: #0087c3 !important; text-decoration: none !important;}a:active { color: #0087c3 !important; }a:visited { color: #0087c3 !important; }table td {border-collapse: collapse;}table { border-collapse:collapse; mso-table-lspace:0pt; mso-table-rspace:0pt; }
> (communities.bentley.com/' title='' target="1">Update from Bentley Communities(communities.bentley.com/)
> [AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message .]
> RE: MC Survey, "Report Mine Width": Is it possible to change a report template? How to do this ?
> SonyaP
> Hi Marek
> Regards
> Sonya
> Did this answer your question?
> Verify it as the answer or Reject it as the answer
> View online
> You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here .
> Flag this post as spam/abuse.
