When using the redline feature in MapMobile simple geometry/text can be captured along with photos and video. eg. circle a pit, make some comments and take a photo. The geometry/text/photo is visible in a panel when selecting the redline feature in MapMobile.
My questions is, once the .markupdb file has been emailed and referenced in Bentley Map, how do you see the comments and photo in Map? Looking at the size of the output .markupdb file it would appear the photo is included in this file.
Thank you.
Alan,
At this time, the Bentley Map extension that provides the ability to reference attach a Bentley Map Mobile redline (.markupdb) file does not support access to the embedded media.
Later this year, we plan to release a new "Bentley Map Mobile - Markup Explorer" that runs inside a Bentley Map session as well as outside as a Windows standalone application. It not only provides access to the embedded media, but adds bi-directional search and geo-locate functionality for the .markupdb vector redline and embedded media data.
Until then, you must use Bentley Map Mobile on any of the available platforms to view the embedded media, where the .imodel and .markupdb files have the same base filename (e.g. MyData.imodel and MyData.markupdb).
If you've an immediate need to access the embedded media, please contact me directly offline to discuss potential alternatives.
Jeff Bielefeld [Bentley]
As always, your feedback is welcomed.
The previously mentioned "Bentley Map Mobile - Markup Explorer" will include a standalone Windows application and Bentley Map add-in, providing users the ability to search, sort, group, view, extract, report and other actions with media attachments. When running the "Bentley Map Mobile - Markup Explorer" as an add-in inside of Bentley Map, users will be able to perform operations like show all media attached to redline elements within a given view, fence or currently selected element(s). In addition, a user can search for media using filename, description, date etc… and then locate the redline elements based upon the selected search results. In summary, users will be able to 1) select a redline element and view attached media or 2) view media and find redline elements. When media is attached to a redline layer or redline element, the user interface provides a thumbnail or list view of the media files.
I offer the following additional comments on the requested Bentley Map Mobile Publisher and Bentley Map Mobile functionality:
Although I cannot provide expected delivery dates for specific enhancements mentioned above, please let me know if you've other questions or feedback regarding planned functional improvements.
