I am struggling to figure out the way for zooming out this display or any other application manager display to see everything without scrolling it?
Hi Farhad. We are adding a zoom in/out feature in the next release of CUBE due this summer (northern hemisphere). I appreciate with modern displays the flow chart can get difficult to view in one shot. Quick tip: holding the SHIFT key whilst scrolling with the mouse lets you scroll left-right instead of up-down. As well as Vu's response below, you can also manually change the size of application and program boxes in the 'Settings' tool bar but this is more permanent.
There are many things that need to be fixed. For instance, to use pan we have to exit from current command and press pan icon and again going back to the previous command. Panning and zoning both have to be added into the mouse/keyboard regardless of changing the current command.
Thank you for your suggestions. We are changing many features in the GIS window in the next release and will take this work flow into consideration. If you have any other suggestions big or small, do please email me directly, I am always keen to hear how we can improve the user experience. oliver.charlesworth@bentley.com
