Hi Team,
To built the network through the application tool. in the input files, are shp file. what needs to put on look up file?
Hi Ruchika. Maybe you should look at this video and see if you can create the network from shapefile by following the steps in the video.
www.youtube.com/watch
Thanks, that was very helpful.
After building a base year model, why we build observed model? Prior and Post Matrix Estimations.
Hello. Could you please clarify your question?
The question was after building the network from the shapefile. There are pre or post-processing steps to build the model prior to the trip generation. What is the reason behind doing pre and post-processing steps?
Hi Ruchika,
I am trying to reply to your questions, but if you are referring to a specific catalog that you are looking at, maybe you would like to share a screenshot highlighting exactly what you are referring to.
Q: "After building a base year model, why we build observed model?"
In general terms, when the model is implemented for a base year, the modelled components are "calibrated" by checking the fit of the model with observed data (observations available for the same base year for, possibly, all the steps of the model). After this process of "calibration" (and typically "validation" and "sensitivity testing") of the model, then, the model is applied to simulate different scenarios under different conditions.
Q: "After building the network from the shapefile. There are pre or post-processing steps to build the model prior to the trip generation. What is the reason behind doing pre and post-processing steps?"
The model structure is designed by the model developer. There could be several reasons behind having some pre-processing or initialization steps before Trip Generation (e.g. in a four-step model). For example: to perform checks on the input network (e.g., consistency with other datasets, like turn penalties, correct definition of attributes, etc.), to create additional network or other data components (e.g., calculation of other attributes, like AreaType, generation of Non-Transit legs for PT modelling, etc.).
