I am trying to mimic a step from a Training Course by Citilabs. The step listed below requires me to select Highway file from a geodatabase but I am unable to do so as the InputNetwork selector wouldn't go beyond the .mdb file. Any thoughts?
Step
How my network program setup looks like
Link to the Training Model files folder (the one I am working on)
Link to the Training Model files folder (the one I Citilabs supplied me with)
When you select the MDB. you should see a list of the datasets on the right as shown below.
If you do not see the datasets panel as shown in the screenshot above, make sure that your Data Manager is working. To do this, click on the data manager icon (screenshot below) and see if it opens. This will confirm that you have access to the GIS functions required to read and write to geo-databases like the CUBE mdb files.
0
If your data manager icon is not active, then it means you do not have the ArcGIS Desktop/Engine installed or might be using a ArcGIS version which is incompatible with the CUBE version. To check the GIS version, click on the help icon on the top right corner of CUBE and select 'About' (screenshot below)
For a list of compatible ArcGIS versions and to further troubleshoot this issue, please refer to Troubleshooting ArcGIS Engine Activation Issues.
