How to convert shapefile to network file and vice versa?
Please have a look at the wikis below:
https://communities.bentley.com/products/mobility-simulation-analytics/w/cube-streetlytics-legion-wiki/47537/how-to-create-a-network-from-shapefile
https://communities.bentley.com/products/mobility-simulation-analytics/w/cube-streetlytics-legion-wiki/47655/how-to-build-a-network-from-shape-while-there-is-no-a-b-node-information-and-get-directions-from-the-shape-file
https://communities.bentley.com/products/mobility-simulation-analytics/w/cube-streetlytics-legion-wiki/53404/how-to-import-export-network-data
https://communities.bentley.com/products/mobility-simulation-analytics/w/cube-streetlytics-legion-wiki/50455/how-to-export-a-cube-binary-net-network-into-a-gis-layer-using-a-network-program
https://communities.bentley.com/products/mobility-simulation-analytics/w/cube-streetlytics-legion-wiki/47632/how-to-export-a-geodatabase-network-into-a-shapefile-using-a-network-program
Answer Verified By: Oliver Charlesworth
