When sketching the network by GIS tool, I am trying to add a new attribute in the network. I have tried "start editing" and "stop editing", but I can not use below function to add new filed.
On the other hand, I tried to open the Table, but I still cannot add new filed.
Could anyone please help me to solve it?
Thank you very much.
Jeff
oh, I sort it out. This ticket can be close or deleted. Thank you.
I see that you already solved the issue, but for the purpose of sharing this in the forum I think that possibly the problem was that the network layer was not selected in the TOC in the CUBE GIS window. The layer that is selected in the TOC will activate different functionalities in the ribbon.
