How to assign zones to a network?
Thank you
If we already have the network (*.NET) and boundary (*.SHP) files - both layers should be active/shown, we can use "Automatic Add Centroid" from Node tab in Network Tools.
I have the network file but not the boundary shapefile.
Maybe we can just manually Add the nodes from Post Node in Home tab.
I see. Thank you
How is adding nodes linked to assigning zones? Sorry, I am new to cube I did not understand.
