Hi,I am working on ODM calibration with Analyst Drive, but it keep failed.What does "Return code of 194 SIGNALQQ SIG$SEGV Error. Illegal storage access" mean? Which part should I check/look at with this type of error?I've checked the Analyst Drive Reference Guide, but found no hint.Thank you.
Hello. What version of the software are you using? And what is your model specification? i.e., static matrix, multi-class, etc.
Cube ver 6.4.5; Analyst Drive ver 1.6.26;
static matrix; single class userI set following options to true/false:CONFMAT (T), USECONF (T), TRIPENDS (T), AUTOTE (T), STATS (F), CNTCONF (F)
Thanks. There could be a few reasons behind this. Could you please file a Service Request under connect.bentley.com for CUBE Analyst Drive product and share with us the files to test?
I just tried to file a Service Request under connect.bentley.com, but it says I have no permission - Error TXH 1138.
Currently I use instructional license from the university.
Is there any other option to share the files?
