Hi, I'm excuting several scenarios with "run multiple" tool but it suddenly stopped with no error message. When I look at the programs .prn files I found that it is stopping in a higway step and it just stopped running i.e. at iteration 14, no w(), m() or e().
Before that we had to change a couple files to correct the multiple scenario error, but after that it just worked fine for a couple days.
Have someone else exerienced that?
regards
Is happening the same to me
Hi Jesus, do you mean that when you run multiple scenarios it crashes or that you have error with the Highway step at a specific iteration?
Hello Filippo, when I run just one scenario everything works fine but I've got more than 60 scenarios. When I try to run more than one escenarios, it only runs the first one then the task monitor closes with no message or error. Cube doesn't close, just the task monitor. I've tried it in different computers and even with different models and definitively is the software. A friend did run it in an older version of cube with no error, I'm not really sure what version he used but is one before bentley.
Thanks for clarifying. This is a known bug in CUBE 6.5, and we have a fix that we can provide upon request by filing a Service Request under connect.bentley.com. Please select:
