I searched a lot but I couldn't get installation files or setup exe file for Cube. Can anyone help me getting these files?
Hello Farhad,
To get the CUBE (CONNECT Edition) installation file you need to log-in to the connect.bentley.com portal. You will then find the installer under "Software Downloads".
It says this when I click on "Software Downloads". We have subscription from Ohio Department of Transportation.
In the case you get that message but your organization is under SELECT, then you probably don't have the software download role for your specific account. It is the account administrator (Fulfillment Contact) in your organization that should give you this type of entitlement (together with software license entitlement, for once you will install the software, etc.).
Please have a look at the below Wikis for more information:
https://communities.bentley.com/communities/other_communities/licensing_cloud_and_web_services/w/wiki/33564/registered-user-set-up
https://communities.bentley.com/products/mobility-simulation-analytics/w/cube-streetlytics-legion-wiki/52387/getting-started-with-cube-connect-edition-cube-ce
Answer Verified By: Oliver Charlesworth
