My CubeDynasim software is version 6.11. After using CubeDynasim to establish a parking lot, the vehicle always disappears after parking. I checked the layer and various property settings of the parking lot, and did not find the problem. Please help me, colleagues!
The file I uploaded seems to be unable to open, but the entire model file cannot be uploaded. please help me!
Ok, I think i found the issue. By default, the speeds on each lane in Dynasim are 100km/hr. When you created the parking lot, your speed within the lot is 100km/h as well which is too fast. What you need to do is change the SPEED component of the trajectory in the parking lot to say about 0.15 which means 15 km/h. This is also applicable to all the nearby approaching links to the parking lot. If you change this, the vehicles will get parked properly. I hope this helps.
Thank you very much! This question had already been solved successfully!
