Hi
I am having problems to visualize polygons and their colors. I have defined a boundary layer to include TAZ on my network and I have selected zone number as the post option in layer properties. However I am not sure how to change the color of this posted text. The same with boundary line and fill color. I am sure I am missing something, is there documention on visualization for networks and zones.
Thank you.
This is how to change the color of posted text and boundary line: /resized-image/__size/2200x1238/__key/communityserver-discussions-components-files/343665/7180.Picture1.png
The same procedure also can be done to change the filling color.
Hope it helps.
Answer Verified By: Ram B
Thank you for your detailed responses, very much appreciated. For proportional sizing I have to use 'analysis tools'I assume?
Did you mean proportional sizing of the posted text? I don't think we can change the size of the text - I've never done it before, but we can change the thickness/style of the lines.
yes, I mean the thickness of lines.
try to change '1' to higher number to make the line thicker. and '0' to hide the line
Yes, but this changes thickeness globally. I wanted to change based on an attribute value.
We can define the criteria/condition in the 'Criteria' field next to it."Insert" or "Append' to add new criteria.
