Hi
After a multiclass assignment, my results are starting with V_2 instead of V_1. And further down , I have V2_1 etc. Did I do something wrong?
Thank you
Hi Ram,The indexes are automatically appended by CUBE. Your input network to HIGHWAY must have a variable with an underscore _ and as a result, the output starts with _2 and not _1. I see there is an attribute SHAPE_LE_1, so fix that and run it again.Thank you.Vipul
Answer Verified By: Ram B
Thank you. Can I delete .net attributes from the Link Ribbon > Delete ? then do I have to rebuild the network ? or just run the program again?
Yes, go to Network window > Link > Delete under Attribute.
The Select an item windows keeps openining again and again. Am I deleteing attribute link by link ?
Once it says deleted next to attribute, close the window and network. Save.
