Hi
Is it possible to increase the gap between the two bands / bars displayed when using multiband visualization ? In image below, I am visualizing link attributes, but would prefer slightly more gap between bars on both directions.
Thank you
You can specify the offset for the links. Please check the CUBE Base Reference Guide under: 6 Network Window > Common display configuration > Color and style settings
