Hi
While importing shapefiles (polylines) , even after cleaning, sometimes a few pseudo node remain. Is there a possibility to merge links at pseudo nodes ?
Thank you
Ram
Hi Ram You can use Consolidate Links option under LINK tab in network window if you have sequence field available for the vertices.
Thank you.Vipul
Answer Verified By: Ram B
