Hi,is any way to use different parameter excludelink by each scenario?Example (notfunctionally) with scenario dependent variable:
RUN PGM=PUBLIC TRANSPORT
PROCESS PHASE=DATAPREP
IF ('{Scenario_ShortName}'='Base2019') exlist='(LI.NTLEG=0,2,3,4)' ENDIFLIST='walk connection' GENERATE, LIST=T, NTLEGMODE=100, COST=LW.FootTIME, EXCLUDELINK = exlist
Thanks for reply.
Hello. My suggested approach is to generate your "GENERATE statements" in a previous Matrix program, saving them in a text file in the scenario folder, based on any condition or catalg key you would like to use. Then use READ FILE = ... to read the generated file. This will allow to check your final "GENERATE statements" that you are using in PT and also to simplify the scripts.
