Hi all,
Some other pedestrian simulation software, instead of using CAD, allows for a PDF import which is then set as the background. The floor layout can then be drawn with the software's tool.Pathfinder is an example of software that uses image files as opposed to CAD.
Anyone know if LEGION has a similar alternative to importing a CAD file? Instead, a PDF or Image file is imported as a background and then CAD objects can be drawn over top of the image.
Thanks!
Hi Dilip,
Thank you for your suggestion, I will raise this issue to our developer.
Right now only CAD file (DWG, DXF, DGN) is necessary for identifying accessible spaces and clear appearance.
In case you intend to import PDF or JPG for visual purposes, you can insert them in picture format(jpg, png) later over the AVI recording layout in Simulator but still very restrict to adjust.
Hope this help
Saton
Answer Verified By: Dilip Rathinakumar
