Some of the Entities in my model seem to lose track of their destination, getting stuck on stairs or trying to go down those stairs when they should be going up. How can I fix this behaviour?
Thank you in advance.
Hi Pilar, Thank you for your question. Could you please share lgm file and also advise about LEGION version you are using. It could be related to linking error.
I'm using the LEGION Model Builder CONNECT Edition Update 1 10.1.1.1
Here's the file I'm using. Thank you so much for your time.
https://filebin.net/nb4iyy1mufngkv3v
Meanwhile could you please check following points as below:1.Check links used by stair object (Failed link/Wrong link)2.Check if Direction modifier used to change target/final destination unexpectedly3.Check if bad filter or condition used or filtering object used somewhere4.Check if Entities are reverting back to Final destination and it does not exist anymore
I will check those, thank you!
I am not able to access the lgm file that you sent. Could you please send me by email? Thank you.
