I have a scenario where I have two escalators going down and one escalator for entities going up. (Refer to image)
Currently, the red entities follow the red arrows (i.e. shortest distance) to the escalator. The blue entities follow the blue arrows into the corridor (i.e. shortest distance). However, this causes high density around the corner as the entities essentially run into each other. I find that this is unrealistic... realistically, the people represented by the red circles would follow the green dashed path in order to not run into the blue entities. In other words, pedestrians would stay to the right of the walking path.
I am emulating this behavior by using a series of focal nodes linked together to basically force the red entities to take a more realistic path by staying to the right of the walkway/corridor.
My question is whether this is best practices to emulate this entity behavior? Should another technique be used instead?
Thanks!
Hello Dilip,Thank you for posting your queries. I would like to suggest to avoid the congestion around the corner you can add a focal node for red entity in mid of green lines. Although It would be better if you can raise a service request and attach your working file. We can suggest you a suitable workaround after investigation to emulate this entity behavior.
Thanks & Regards,Arindam
Yes I believe the focal node option is what I am currently using. It is working well and emulating the behavior. I was curious if there are other techniques to accomplish this.
I'd like to avoid attaching my working file as it is confidential.
Thank you,
Hi Dilip,
Thank you for your query.
To avoid high density around the corner we can use following objects: 1. Drift zones 2. Focal nodes 3. Route guides as per shown in screenshot below.
Please advise which LEGION version you are using.
Thank you
sheetal
I am using CONNECT Edition Update 1 10.1.1.1. Planning on updating soon, just need IT administrator permission at my company to do so.
Is that lgm file something I can download?
I will create lgm in Update 1 and share with you.
Sheetal
