Hello Everyone, i have a question. Is it possible to have an dashline in LEGION CONNECT Edition update 2? I have prepared data in Microstation CONNECT Edition, but if i import this data to legion, dashlines are changed to full line.
Thx for your answer.
Hi Marek,
The reason dash lines are changed to full lines because dash lines is a single line that displays as multi-lines. As LEGION using every single line to generate accessible space and dash lines will cause conflict to the calculation.
BTW I will raise this issue with developer team for the best we can do.
Regards.
Saton
