Unable to use GIS in Cube
Hi All,
I am using Cube 6.4 and I want to use the GIS editor as described in this post by Ahmed Mohideen. However, the option to make a new GIS map is greyed out, as is the symbol for the Data Manager.
In the past, my understanding is that this issue was caused by having a version of ArcMap installed that is too recent. Specifically, that Cube's GIS window will not work if ArcMap's version is newer than 10.5. Presently I am running ArcMap 10.7.1. Is this the reason that I cannot use the Cube editor? Do I need to downgrade to ArcMap 10.5 in order to use Cube's GIS capabilities? If so, does Bentley have any timeline for when Cube's GIS interface will update to work with later versions of ArcMap, or ArcGIS Pro?
Thank you,
Parents Reply Children
