What is format of input files of gravity model in cube
Trying to run the gravity model program in cube as scripted in cube. It ask for Control data, Matrix:Skim, GM Data and Data file 1 as inputs. Can someone explain what are these files and what is the format of these files.
Thank you
  • Hi Nikhil,
    See the attached PDF which provides the definitions for the files. In terms of what formats are supported for these files, in CUBE, if you click on each of the file's box, it will tell you what format is supported, e.g. .DAT, .MAT, etc. Double-clicking on the control data file (CTL), will allow you to set the parameters and options of the program itself.
    4478.GRAVITY MODEL.pdf
    NOTE: TRANPLAN and its programs are legacy and not supported anymore. You should use the Voyager's DISTRIBUTION program. This is found in the CUBE Voyager Reference Guide > Chapter 10: Distribution Program. You can access it in CUBE itself from the Help icon in the upper-right of the screen (blue "?" icon).
    There is an example of this from our Cubetown > Cube Voyager Demonstration Model. It is found in the Trip Distribution group (step #4). You can download Cubetown here: Cubetown.
Reply
  • Hi Nikhil,
