How to add a python application into a loop and access the loop variable within the python script?
Considering the following loop
How could the python script access the variable PID ?
Thanks for the help !
Damien
  • There is no direct way of doing this but there is a simple solution. You can add a PILOT program to print out a Python file (..py) with the variables, and then import this into your Python script.
    PILOT program code
    PRINT LIST='a= 100' FILE="variables.py"
    PRINT LIST='b= "cube"' FILE="variables.py"
    Python code to import variables
    from variables import *
    peint(a)
    print(b)
    Hope this helps!
  • As an alternative, you can also pass the token directly as a sys.argv to your Python script.
    For example, in a more general case, let's call the variable "loop_variable" defined as below (just as an example, in a Pilot program or within the Loop circle properties):
    loop_variable = 12
    Your Python command line could look like the below in a Pilot script direclty:
    *"C:\Program Files\Python311\python.exe" "{CATALOG_DIR}\Applications\python_script.py" @loop_variable@
    Then, your Python script will look like the below (just an example):
    import sys
    loop_variable = sys.argv[1]
    with open("D:/some_path/Base/out_txt.txt", "w") as txt_file:
        print(loop_variable, file=txt_file)
    This will print out 12 in your output text file.
  • Hi Ahmed
    Thanks for the reply, this isn't what I was expecting but your answer provided a good tip.
    I used a pilot to print a data file with the PID value, and added this file as an input in the python script
    And it works!
    Damien
