MAXSURF CONNECT Edition 21.14 is now available
The MAXSURF product team is pleased to announce the availability of MAXSURF CONNECT Edition (Version 21.14.00.04) on the Fulfillment Center.
NOTE: This is an update and will overwrite earlier installations of MAXSURF 21.13.00.19, etc.
Full details are explained in the read me.
A key addition is the ability to mesh and export structural parts (decks, plates, frames, longitudinal girders, etc.).
We have also added support for the EU Inland Waterways stability criteria ES-TRIN 2017.
The way in which you are able to combine both NURBS and Trimesh surfaces in the same model and select which surfaces should be used for different analyses, (first introduced in 21.13) has been ehanced.
This is explained in greater detail in this video:
Combining both NURBS and Trimesh surfaces in a MAXSURF design file
