Coffee Corner: Bentley Offshore - Calculating Hydrodynamic Damping in MOSES.
Title: Coffee Corner: Bentley Offshore - Calculating Hydrodynamic Damping in MOSES.
Presenters: Spiro J. Pahos, Application Engineer -  Offshore, Bentley Systems Inc and Georgina Maldonado, Application Engineer - Offshore, Bentley Systems Inc
Date/Time: August 11, 2021 at 10:00 AM EDT
Register Now!
The August 2021 Bentley Offshore Coffee Corner explores how to calculate hydrodynamic damping with MOSES. Topics include:
  • Finding the damping coefficient of a free floating barge with first principles.
  • Studying the effects of hull geometry on damping coefficient.
  • Validating results
Bentley Offshore Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
**The webcast will be streamed through your computer, so there is no dial-in number.  Please make sure your computer speakers (or headset) are turned on and the volume is set to an audible level so you can hear the presenters.  Help
