Hello all, Is it possible to import AutoCad drawing or SAP 2000 file to SACS as input file?
I have a complex configuration of a jacket created in SAP2000 and I want to import this file to SACS.
Yes, you can export the model from SAP2000 using the "Steel Detailing Neutral File" format. SACS can import this file format from Precede. First create a new blank model and then select "Import/Steel Detailing Neutral File" as shown below.
Answer Verified By: Bill Genemaras
The recommended methods for exporting models from Staad.Pro to SACS are using the Export to SACS feature or using the integrated structural modeler.
The Export Model to SACS feature is located under Tools -> User Tools -> Export Model to SACS:
The integrated structural model export is located under File -> ISM -> Create Repository:
You can then import the model in SACS under File -> ISM -> New From Repository:
Geoff
You can also Create and save a DWG model within AutoCAD to import SAP 2000 file to SACS as Input file. still you have any issue regarding this then you can contact contact to SAP Implementation Partner support who provide all the solution regarding SAP ERP issue.
SAP Business One Partner
Yes, Hamid, It is possible to import SAP 200 file as input file. If you want to solutions then you can contact with any Authorized SAP Business one partner for support.. Thanks!
