Hi there,
I've imported a submarine Rhino 3dm file into maxsurf. It seems to recognise the outer hull as a surface, however the display is rather confusing (see attached pictures). Also when I open this file in maxsurf stability it does not recognise the outer hull.
Anyone have a solution to this unique problem?
