Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
MAXSURF | MOSES | SACS | OpenWindPower
MAXSURF | MOSES | SACS | OpenWindPower Forum
Offshore Structural Analysis
Sign In
State
Not Answered
Replies
Subscribers
24 subscribers
Views
Users
0 members are here
analysis
SACS
Offline
Sid
over 7 years ago
Is it possible to define a sling/ rope with pretension inside SACS?
0
Offline
Vul Thang
Tue, Jan 5 2016 3:19 PM
You can apply axial force in the sling if you want to. But, any reason why do you want to have pretension?
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
Sid
Tue, Jan 5 2016 9:26 PM
in reply to
Vul Thang
Thanks for replying. I want to restrict the bending of an offshore column.
I have created four slings, diagonally connecting the column (at a height 2/3rd from the base) and the seabed (pinned joints). The slings are gap element (tension only).
When I run the analysis, I find very low tension on the slings. Whatever displacement the column bends to is compensated by an extension of the sling . Hence the slings do not restrain the bending of the column. I feel if I can add pretension to the slings, I can restrain the column from bending.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
Vul Thang
Wed, Jan 6 2016 11:23 AM
in reply to
Sid
If your slings are slacking, you may get low tension forces as most of the forces will be taken by the column itself. You may like to model the sling straight so that they will take tension forces the moment column bends. Also, you may like to increase the stiffness of the sling by increasing its diameter/cross section area so that there will be little displacement in the sling itself. Also, release the moment at the end of the sling connecting to the column so that you will get only axial forces in the sling. You can then look at the base shear at the column and axial forces in the slings.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
