Hi
I am unable to see the results (e.g. Maximum combined UC) for different loadcases/ load combinations. Within precede I select 'loadconditions' within 'options' at the same time from within postvue (within results tab) selecting loadcases from 'available' load cases but there is only one set of UC and displacement etc. is available -does not change for different loadcases!!!
same applies for reactions.
please suggest what is it that I am doing wrong?!
Thanks.
You can modify which load cases are visible by opening the Load -> Activate List dialog and selecting which load conditions are active.
Answer Verified By: Geoff McDonald
