Hi
Is there a way to check the correctness of the data within input files like psiinp, seainp etc. similar to checking model within precede?!
Many thanks.
With seastate input files, you can import them into your SACS input file using File-> Import-> Import Seastate and then running the Check Model option.
PSI does not have the same feature, but a good way to check PSI is to run the Polot Soil Data utility. This will generate the P-Y and T-Z curve charts so that you can visually inspect your data.
Geoff
