Can I use wave seeds in moses to generate five different random waves for a time domain analysis. And I want want to restrict the analysis around peak wave elevation say 150 seconds to study the forces and motion in detail.If yes please mention the commands..
Sharath
AbuDhabi
Hi Georgina,
What are the other options which change the seeds?
What are the values of seeds to be used? I checked Moses files and found TB=18000 is used with all -t_reinforce options.
Best regards,
Ahmed
Best Regards,
Ahmed Raouf
Offshore installation engineer
Technical support department
Petroleum Marine Services Co.
EGY Mob: +2 0100 1712041
Hi Ahemed,
Thank you for your question. Yes, -t_reinforce is the option for setting the seed.
I have also seen people use the "-time tobserv delta_time ttra_set ncycle" to control when the maximum environment occurs.
I do not understand your question. The default is TB = 18,000. Maybe we need to define what is "seed".
From Wikipedia, "A random seed is a number used to initialize a pseudorandom number generator." MOSES is using the TB, seed, to pick the phases of the frequency components. We try to model a random sea. The phases are what we are trying to make random.
I hope this helps.
georgina
Don't forget that if using -t_reinforce, TB must be a high number (i.e. larger that the simulation time), since at this point all the Fourier components add up and creates a huge wave - if I recall correctly.
based on mp_moor, i tried to input different values of t_reinforce,TB.
T_REINFORCE = T_REINFORCE IS NOT ADDED IN &ENVMAX = 100.14 99.48 99.40 99.73 152.48 179.99 180.15 148.42 PRED_MAX = 105.33 106.46 106.25 104.72 164.01 198.05 198.02 158.44MAX_MEAN = 13.84 18.00 17.84 13.32 31.64 48.54 48.40 27.85PRED.MAX_MEAN = 19.02 24.98 24.69 18.32 43.17 66.61 66.28 37.87
T_REINFORCE = 0MAX = 99.93 99.55 99.57 99.74 145.62 169.80 170.59 145.36 PRED_MAX = 104.91 106.14 106.10 104.55 155.10 184.34 185.36 154.79 MAX_MEAN = 13.28 17.45 17.42 12.93 25.65 39.64 40.26 25.53PRED.MAX_MEAN = 18.26 24.04 23.95 17.74 35.12 54.18 55.03 34.96
T_REINFORCE = 5MAX = 101.92 102.27 102.29 101.55 145.57 172.38 172.24 145.25 PRED_MAX = 107.75 110.13 110.14 107.23 154.68 187.38 187.12 154.30MAX_MEAN = 15.49 20.37 20.34 14.97 24.83 40.89 40.56 24.65PRED.MAX_MEAN = 21.32 28.23 28.19 20.65 33.94 55.88 55.44 33.70
T_REINFORCE = -5MAX = 101.92 102.27 102.29 101.55 145.57 172.38 172.24 145.25 PRED_MAX = 107.75 110.13 110.14 107.23 154.68 187.38 187.12 154.30MAX_MEAN = 15.49 20.37 20.34 14.97 24.83 40.89 40.56 24.65PRED.MAX_MEAN = 21.32 28.23 28.19 20.65 33.94 55.88 55.44 33.70
T_REINFORCE = 10800MAX = 94.31 91.20 91.58 94.46 136.09 155.83 155.66 136.16 PRED_MAX = 97.56 95.25 95.81 97.71 141.51 164.88 164.57 141.67MAX_MEAN = 8.87 11.04 11.36 8.80 15.06 24.31 23.95 15.30PRED.MAX_MEAN = 12.12 15.09 15.59 12.05 20.47 33.35 32.86 20.80
My question is to follow guideline from BV 493-NR, i need n=5 and i believe the option T_REINFORCE 5 is the correct way to do it? Since moses cant produce result of Tk of each seed (elementary wave), how can i calculate the value for
Tm : Mean of the n maximum values of Tk? Is the given Max_mean Value = Tm? I hope you understand my question.
