Thickness Reference (tref) in SACS Built-in S-N Curve
Dear Sir,
Do we have any command to change thickness reference in built-in S-N curve in SACS?
For example,
Thickness reference for tubular connection should be 32mm for DNVGL-RP-0005 (2014) S-N "T" Curve.
However, SACS used tref = 25mm for this curve which will provide too conservative fatigue output.
Currently, I have to manually key-in S-N curve by myself. This have a problem as I have to create two S-N for both underwater and air which make me 2 fatigue runs.
If you have any command to override this thickness reference of SACS built-in S-N, please kindly help to let me know.
If we cannot override this tref, please kindly put this issue into your future development.
Kasiphon
