User Defined section database
Hi
How can we create a user defined section database and use it in SACS ? Can we include library sections also into this ?
Do we have an option save the information in separate ASCII file and use it?
Request for help and suggestions.
Bhargav
  • Hi Bhargav,
    You can create user defined section libraries within the Datagen, under the 'Static' File Type the option is called 'Section Library File'. This will give you all of the inputs needed to create a user defined database, you can add sections from other section library's if desired. Once you have created your own section library make sure to save it as .sec and then you just have to select it in the analysis generator:
    Hope this helps.
    Jed
